Pinion nut
Old Feb 27, 2013 | 11:24 AM
mmguy18's Avatar
mmguy18
Talking Pinion nut
Need to change pinion seal. Does anyone know the torque on the nut?
Old Feb 27, 2013 | 01:18 PM
dodgeramguy85's Avatar
dodgeramguy85
Initial torque is 210 ft.lb but before you take it off use a in.lb torque wrench and see what the resistance is to spin the axle. Tighten to its initial tq then measure it with your in.lb till you get the same reading as you had before disassembly.
Old Feb 27, 2013 | 01:26 PM
moe7404's Avatar
moe7404
my 2001 dakota factory service manual shows. both 9 1/4 and 8 1/4 axles for the pinion nut min, 210 ft lbs. its been a long time since i worked with them. but i would put loc-tite blue on the threads, just enough you dont want it on the bearings just dont get it to tight of to lose.
Old Feb 27, 2013 | 08:18 PM
mmguy18's Avatar
mmguy18
Got a cheap Craftsman torque wrench I can check the resistance with. Definitely on the thread lock. Going to change the oil while I am in there. Only got about 23,000 since last one but couldn't hurt.
Old Feb 28, 2013 | 01:32 PM
moe7404's Avatar
moe7404
how are you going to hold the axles, when putting 200 lbs of pull on it?
Old Feb 28, 2013 | 02:13 PM
dodgeramguy85
Chain wrench or pipe wrench on the yoke as you tighten it.
Old Feb 28, 2013 | 09:17 PM
Tom A's Avatar
Tom A
Section Moderator
Or have somebody step on the brake.
Old Feb 28, 2013 | 10:39 PM
magnethead's Avatar
magnethead
this.
