2004 dakota Transmission fluid question
Hey guys i have a 2004 dodge dakota 4x4 4.7 qc with 545rfe 5 speed auto that my step mom bought brand new. The tranny pan started to leak the other day so i got a diiferent one. I also got a bunch of atf+4 and a pan gasket and trany filter kit. My question is after everthing is put back togeather, when i got to add fluid do i fill with the 5.5 quarts, drive it, then top it off or is there some kinda procedure for it to be done correctly? Thanks
The hard part, doing a drain and fill, is figuring out how much to put in. I usually put in enough to bring it to full, not running. Start it and fill it until "full." Then shift it through all the ranges a few times, checking the level, then going for a ride, and topping it off again.
I'd rather not overfill it. It won't really ever run dry this way so I'm not worried but it's been a while since I've done an auto. Maybe someone else has a better idea.
The book says to put in about 5 quarts at first, then check.
"(2) Add following initial quantity of Mopar® ATF +4 to transmission:
(a) If only fluid and filter were changed, add 10 pints (5 quarts) of ATF +4 to transmission."
ok thanks man thats the way i was gonna try it, i just wanted to be carefull because the more i research the 545 rfe im finding out its a realy complex tranny. Mine has 190,000 and honestly with the step mom having the truck, i think the fluid was changed once at 60,000 or something and thats it
you might want use an external oil filter. i think most chrysler trans are 3/8" tubing.
man o man i about forgot yes its a cut & past sorry. __________________
after you clean the trans. add this to your*chrysler*trans. an external fluid filter
1. go to auto-zone. get 2210, its called a power steering filter, but it is for transs to. it is for 3/8 tubing. by (magna-fine) be sure to use high pressure hose. Reff:http://www.magnafilter.com.au/magna-fine.html*
2. for other sizes wix 58964 5/16 tube size reff:http://www.wixfilters.com/filterlook...sionfilter.asp
when we first got our ram in 05, we had this issue the first 2 fluid changes.
