modern Magnum block vs LA block vs SBCh
Old Mar 11, 2013 | 06:39 PM
magnethead's Avatar
magnethead
Default modern Magnum block vs LA block vs SBCh
What are the differences between the modern Magnum block, the LA block, and the old Small Block Chryslers?
What all is interchangable?
Old Mar 11, 2013 | 08:23 PM
magnethead's Avatar
magnethead
I ask because Theres 2 local racers that still run mopar stuff, and a third that just switched from mopar to chevy, and has mopar stuff laying around. Most of their stuff is BB chrysler, but they know where small block stuff is, that I might want to buy in the future if it will bolt to the magnum block...
I'm talking universal-to-V6-and-V8-stuff- starter, oil pump, distributor, valvetrain, things like that.
Old Mar 11, 2013 | 08:50 PM
98DAKAZ's Avatar
98DAKAZ
magnethead
You know these Dakota engines very well correct?
I'm going to get a newer 2-nd gen Dakota around a 2002 to 2004 This will not happen any time soon but in your opinion is the V8 a better engine than the V6?
I have the 2.5 now and I'm very happy with it as its a dependable little Nut and very easy to keep up so a V6 may do me?
I may even look at older ones 1998 to 2000
This is a bit of fun were I live I see many 2-nd gen Dakota driving around all in good shape
Thanks
Old Mar 11, 2013 | 09:33 PM
magnethead's Avatar
magnethead
Originally Posted by 98DAKAZ
magnethead
Thanks
you will have a PM shortly.'
Another thought. What if I were to break all the laws of appearing stock, and put a BBC chrysler block (like a 440) in down the road, instead of building a 408 small block? Would the driveplate/crank position sensor transfer over (I doubt it)? I know the motor mounts would be custom, but what wouldn't be at that point. I suppose I could go to a megasquirt at that point, but I don't know how those connect to the dash and CTM. That's why i was thinking to spend the extra money, and just make a 408, and live with less power.
(This all assuming I ladder-bar the truck eventually)
