Heater/AC fan
Old Mar 14, 2013 | 11:21 AM
Edgybob's Avatar
Edgybob
Default Heater/AC fan
My fan stopped working all of a sudden in my 03 Dakota.
I tried all the fuses and they look fine. Had to check all of them because there is no "Fan motor" fuse label.
Is there anything else I should look at? I am hoping it is not a bad fan motor. If it is a bad fan, how difficult are they to remove/replace?
Thanks
Old Mar 14, 2013 | 11:32 AM
98DAKAZ's Avatar
98DAKAZ
Another forum but its a good one http://www.dakota-durango.com/forum/...ad.php?t=65326
Old Mar 18, 2013 | 02:56 PM
Edgybob's Avatar
Edgybob
More Info... After being dead for a week, my fan started working without notice. Then, just as suddenly, it stopped. Then it started gain. Then it stopped.
So it works intermittently with no warning or notice, it will just come on/go off.
Makes sense it is the blower motor control module / resistor. Right?
Old Mar 18, 2013 | 03:48 PM
magnethead's Avatar
magnethead
thats my guess.
98DAKAZ's Avatar
98DAKAZ
The problem may be in the control unit 00DakDan knows this stuff better than I it may be a poor ground strap
look at this see the ground
Old Mar 18, 2013 | 05:15 PM
00DakDan's Avatar
00DakDan
Section Moderator
I'd check out the resistor first, it's a known problem area. After that, check the grounds.
Old Jun 20, 2013 | 09:36 PM
woodeman's Avatar
woodeman
I just repaired this on my '03 today. Same issue, no fan. Put in new resistor block, pulled the fan and ran it on the bench. Ran fine and fast. Put it all back together and it runs fine now. Took about an hour to complete but that's because I'm not as flexible as I used to be.
Old Nov 13, 2013 | 08:56 PM
Edgybob's Avatar
Edgybob
I replaced the resistor block several weeks ago. After about 2 months the fan stopped working again. I replaced the block with a better one and it worked fine for a few weeks then it stopped again and works intermittently now.
Am at my wits end. Some one said it might be a bad ground. Not sure where to even where to look for a ground terminal.
Driving me nuts.
Old Nov 13, 2013 | 10:20 PM
magnethead's Avatar
magnethead
Driving me nuts.
wherever ground point number 207 is location, per the diagram above.
Is the plug melting?
Old Nov 14, 2013 | 10:17 AM
Edgybob's Avatar
Edgybob
Thanks.
I can see the diagram, but your guess is as good as mine where the heck that is.
Was hoping for a little more clarification
