Torsion bar won't install
Old Mar 22, 2013 | 07:58 PM
Kmerr98277's Avatar
Kmerr98277
Default Torsion bar won't install
I am in the process of replacing my control arms and can't get the t bar to install. If I install the bar in the key I can't get it into the lower control arm. If I install the bar in the control arm I can't get it in the key. What am I doing wrong?
Old Mar 22, 2013 | 10:15 PM
Crazy4x4RT's Avatar
Crazy4x4RT
What year of truck do you have so I can move this into the correct forum?
Old Mar 22, 2013 | 11:52 PM
Kmerr98277's Avatar
Kmerr98277
My bad. First day. 2001 dakota 4x4 3.9l
Old Mar 23, 2013 | 07:29 PM
jpayne80's Avatar
jpayne80
When I replaced my lower ball joints I had to remove the control arm with the t-bars still attached. I could not get them apart. But I was able to get everything back together. I slid the end of the bar into the key, which was loose, and used a jack to position the control arm where it needed to be. Then I tightened the key bolts and control arm bolts.
Hope that helps a little.
