wheel bearings or ball joint help
Old Mar 23, 2013 | 12:26 PM
david9516's Avatar
david9516
Default wheel bearings or ball joint help
I have this ho hum sound coming from my right drivers side tire area. it seems wen going straight or turning right it is pronounced and if I turn left it seems to go away. I have a lot of tire noise. also I took a sharp turn to right yesterday and heard a clunk from same area. I haven't had a lot of experience with this type of prob so ne advice will be helpful. im driving a 2002 Dakota 4x4 slt qc 4.7l.
Old Mar 23, 2013 | 12:51 PM
Tom A's Avatar
Tom A
Section Moderator
Jack up the front wheels one at a time. Grasp the tire at the top and the bottom and try to rock it from side to side. If it moves, have somebody else look under neath the truck to see if the movement is in the ball joints or the bearings. If it doesn't move back and forth, rotate the wheel slowly by hand and feel for any roughness. That would be wheel bearings.
It sounds to me like your problem is bearings (assuming, of course, that your brakes aren't metal-to-metal or something like that).
Old Mar 23, 2013 | 01:08 PM
david9516's Avatar
david9516
brakes are all good. one other thing I forgot to put in is wen im drivn on the ****ty side rds it feels kinda loose and sounds like a clunking. does the ball joints affect ur alignment at all. the truck doesn't veer either way or pull at all. brakes rubbing would make it pull a lil right
00DakDan's Avatar
00DakDan
Section Moderator
The hum is a bearing, most likely the right front. You may not be able to feel any play in it unless it is really bad.
The clunk could be a ball joint.
Old Mar 24, 2013 | 03:41 PM
david9516's Avatar
david9516
I hacked the truck up and found wat i think is bad wheel bearings. Is it right that yhe whole hub assembly moves is that just the bearings or does it mean that there is more probs. Correct me if im wrong but the whole assembly has to be replaced with the bearing right? Wat is the pressure that i need to torque on it wen i put it back together. Thanjs for all the help so far
Old Mar 24, 2013 | 03:55 PM
david9516's Avatar
david9516
So i found a site that said the torque on tue castle nut should 185lbs. Does nebody know if thats correct
Old Mar 24, 2013 | 04:18 PM
Vladek's Avatar
Vladek
hub/bearing assembly-to steering knuckle nuts 123 ft. lbs. (via chilton book)
Old Mar 24, 2013 | 04:19 PM
Vladek's Avatar
Vladek
123 ft. lbs. hope it is showing the numbers. but if is isn't here is this. one hundred twenty three ft. lbs.
Old Mar 24, 2013 | 04:36 PM
david9516's Avatar
david9516
Its not showing numbers. I see u wrote it tho. Thanks. Thats for a 4x4 correct?
Old Mar 24, 2013 | 04:38 PM
david9516's Avatar
david9516
Thats for the three nuts that connect the assembly to the knuckle. Is it the same for the castle nut
