ticking sound on cold starts
Old Mar 26, 2013 | 03:02 PM
ryan_brown33's Avatar
ryan_brown33
Default ticking sound on cold starts
The past few days it has been colder than normal (single digits at night and teens in the morning going to work). When I start my truck there is a ticking noise that sounds like a card in a bicycle wheel coming from pass. side of the engine. It is gone before then engine even reaches operating temperature. Anyone know what it could be or had this happen before ? It is a 2002 4.7L
Old Mar 26, 2013 | 03:27 PM
Vladek's Avatar
Vladek
lack of oil at start-up, til the oil pump get things going??, exhaust leak at manifold/head or manifold/pipe.
just guessing
Old Mar 26, 2013 | 04:36 PM
Dodgeboy77's Avatar
Dodgeboy77
how long has the oil been in? some motors use that to tell you it's time to change.
Old Mar 26, 2013 | 07:59 PM
jpayne80's Avatar
jpayne80
Probably typical 4.7 lifter tick or exhaust leak at manifold gasket due to broken header bolt(s). Both are very common.
Old Mar 26, 2013 | 10:23 PM
ryan_brown33
I don't think its lifter tick because it usually has a quiet tick that you have to be paying attention to hear it, this is way different. Oil level is good and I am 5,000 since change but it has been on full synthetic for a long time and it shouldnt need changing yet. How would I diagnose an exhaust manifold leak and fix it if that's what it is ?
Old Mar 27, 2013 | 07:07 AM
inflatablejesus's Avatar
inflatablejesus
could be a bit of piston slap from the cylinders being a bit worn at high mileage.
one of those stethoscope's with a probe on it is good for finding the noise and can be had cheap at the autoparts store.
Old Mar 27, 2013 | 08:49 PM
Dakota~N~Camaro's Avatar
Dakota~N~Camaro
I thought my engine was fixing to come apart, I put the scope over every square inch of my engine and had normal sound, finnaly put it on a injector and it sounded like a diesel, IDK why but they are loud as can be at first start up. I have never heard injectors this loud before
Old Mar 27, 2013 | 09:04 PM
jpayne80's Avatar
jpayne80
The injectors on my Titan were the same way; very loud. Irritated the crap out of me.
Old Mar 29, 2013 | 10:18 AM
jondakotaguy's Avatar
jondakotaguy
I have a thread around here somewhere discussing the same exact thing.. on my 5.2L only thing I could conclude was not enough luberication at startup when its really cold.. only get a few tick's then it goes away right away.. that tells me its lubrication related on the rocker/lifter.. or what ever.
