lights stay on
Old Apr 1, 2013 | 12:31 PM
jimheh's Avatar
jimheh
Default lights stay on
The park, tail, license lights stay on when switched off. Have do disconnect battery cable to turn off. Headlight switch?
Old Apr 1, 2013 | 11:51 PM
Crazy4x4RT's Avatar
Crazy4x4RT
What year of truck do you have I can move this there?
Old Apr 2, 2013 | 12:30 PM
jimheh's Avatar
jimheh
2001 Dakota Sport. I disconnected the headlight switch and the Central Timer Module and the lights still stay on.
Old Apr 2, 2013 | 01:10 PM
00DakDan's Avatar
00DakDan
Section Moderator
In the junction block on the side of the dash, pull the "park lamp relay." It should be right hand relay. The contacts MAY have fused.
The headlight switch tells the CTM to apply power to the "park lamp relay" when you turn on the lights.
Swap it with the one next to it, the horn relay. See what happens.
Old Apr 3, 2013 | 05:18 PM
jimheh's Avatar
jimheh
Thanks fror the suggestion. Tried that. No change. I think there is a short to 12V in one of the light wires somewhere in the body. Temp fix is a battery disconnect switch.
