tom when u jacko the front tires up do i need to do anything else or do i just start removing the torsion key bolt
As long as the front tires are hanging in the air, you should be able to just remove the bolts. They should start to get loose right near the end.
Make a note of how many threads are showing (may be different left to right) so you have an approximation of where to adjust them when you get the new keys in.
Also, you're going to need a big prybar to pry the torsion bars down far enough that the keys drop out of the crossmember and you can remove them. After you pry them down, stick a block of wood in there to hold them and hammer the keys off (might take some serious hammering if they're rusted in place).
