truck is not happy, lots of MIL
I cleared them with the SCT, so we'll see what pops back up. This is the order as appeared.
1388 - ASD control circuit
0301 - #1 misfire
0305 - #5 misfire
0303 - #3 misfire
0300 - Multi-cyl misfire
0455 - Large evap leak
I find it peculiar, all one bank. Evap leak used to be a small leak, now it's a large leak.
If I slap the throttle with the engine cold, it'll backfire through the intake and simply wont make RPM/power. All's fine with it warmed up.
Not sure what the 1388 ASD relay code is for/about.
I'm not real sure where to start?
I'm probably going to be putting the MSD on this weekend, so that may exacerbate any issues I have. A plug and dizzy check is definitely in order. Plugs aren't that old but need to be gapped 50-60 for the MSD, dizzy cap is new.
Really hoping I don't have a bum valve spring. The motor is seeing 5,000 RPM alot now that I'm racing it, and I have the HS 1.7 rockers, so the springs are getting a good workout. Same with the timing chain, hopefully the cam isn't loose and bouncing around. I could put a timing light on it, but there's no pointers that I can find to time off of?
0301 - #1 misfire
0305 - #5 misfire
0303 - #3 misfire
