How hard is it to change a 2wd to 4wd
Old Apr 20, 2013 | 10:12 PM
fldodge4x4's Avatar
fldodge4x4
Default How hard is it to change a 2wd to 4wd
What do I need how do I do it? Have to do it.
Old Apr 21, 2013 | 12:57 AM
Custer's Avatar
Custer
I couldn't say other than...Buy a 4X4. lol
For those who can help you you should give the details of your truck, i.e.
Year
Body
Engine
Tranny
etc...You get the point.
Old Apr 21, 2013 | 04:16 AM
fldodge4x4's Avatar
fldodge4x4
Year
Body
Engine
Tranny
2001 supercharge 360 quad cab four door bad *** truck
Old Apr 21, 2013 | 09:17 AM
emesnarf's Avatar
emesnarf
Getting a 4x4 truck or parts there of for the 4wd chassis with the same cab box combo would be the easiest way if you have some investment in your bodywork. Or get a 4x4 that's the trim level you want and swap your hopped up stuff to the new truck. The front end of the 2wd truck frame is quite different.
Old Apr 21, 2013 | 11:03 AM
dodgeramguy85's Avatar
dodgeramguy85
You are better off to throw your motor in a 4wd truck. It will take lots of work and fab skills. For the very little you are gaining imo it isnt worth it.
Old Apr 22, 2013 | 01:52 AM
magnethead's Avatar
magnethead
Just off the top of my head
4wd lower control arms
torsion bars
torsion keys
torsion crossmember
differential (w/ matching gears to rear axle) and output shafts (with fresh CV joints)
transmission/engine/front differential bracketry
transmission to transfercase coupler
transfer case
both driveshafts
4WD PCM (for transfercase control) that matches the truck's original, and transfercase wiring harness
Which adds up to what you could get another truck for.
Old Apr 22, 2013 | 08:15 AM
Tom A's Avatar
Tom A
Section Moderator
It would be much easier (and probably cheaper) to put a solid axle in the front than it would be to install a stock 4x4 front end.
Old Apr 22, 2013 | 10:49 AM
magnethead's Avatar
magnethead
my thoughts exactly. With a manual transfercase so PCM doesnt get involved.
Old Apr 22, 2013 | 10:57 PM
GM1697's Avatar
GM1697
make it a pre runner.
long arm suspension in the front, cheaper than any of the options discussed so far.
it would still be 2wd, but you could run real aggressive 35's and it would be way more badass.
