Gearing.
Old Apr 25, 2013 | 12:02 AM
01blackdak's Avatar
01blackdak
I don't really take the truck on long trips anymore. Mostly just around where I live and an hour n' half drive south for biking/camping.
I plan on going up in gears because I eventually plan on getting bigger tires(315/75/16)/possibly new wheels & body lift once my new tires wear out. I just don't want to put a lot of extra load on the engine and transmission.
Hopefully I'll get more out of these new ones than my old ones.
Old Apr 25, 2013 | 12:48 AM
magnethead's Avatar
magnethead
You have the 4.7 and 3.92's, 4.10's won't be worth the investment. You have the same transmission that the Hemi gets in the ram's, so it won't mind a little more drag.
That said, 315/75/16 is a 34.5 inch tire. You'll want 4.56's for that much meat. Hell, even 4.88's may not be a bad idea. You're in TOM A's department now.
Old Apr 25, 2013 | 08:59 AM
Tom A's Avatar
Tom A
Section Moderator
My truck works surprisingly well with 4.10 gears and 315/75-16 tires. But if I were going to do it again, I would go with 4.56 gears instead. If I didn't drive on the freeway so much, I would probably think about 4.88s. I may still end up switching to 4.56s some day.
The 4.10s were perfect with 33s, IMO.
Old Apr 25, 2013 | 03:21 PM
01blackdak's Avatar
01blackdak
I'll keep the 4.56 in mind I'm still not 100% on which size tire I'll wanna go with. Either 315/75r16 or 305/70r16. Just depends how much cash I have when the time comes for new tires. And even now with the 31's I have I still try to avoid highway driving when I go into town.
I eventually plan on doing an SAS but that is a long ways off. Figure this will be more beneficial for me in the long run since IFS isn't that practical for wheeling on the trails since there are a lot more parts that can break opposed to a solid axle.
