Ticking in engine
Old Apr 30, 2013 | 06:56 PM
jacobclif_9's Avatar
jacobclif_9
Default Ticking in engine
Sometimes when I first start up the truck and back up or when I'm moving slowly through a parking lot there is a ticking and rattling in the right side of the engine. It's not when I accelerate or anything I'm just not sure what it is but it makes the truck sound junky.
Old Apr 30, 2013 | 07:18 PM
sxrsil3nt's Avatar
sxrsil3nt
Exhaust manifold bolts?
Very common problem on the Ram's.
Old May 1, 2013 | 01:26 PM
Blacknights's Avatar
Blacknights
Does it sounds like metal hitting metal? And is the frequency constant? Almost like it is your valves making the noise?
Old May 1, 2013 | 06:06 PM
jacobclif_9
It's just a quick little rattling like something is shaking lightly for a few seconds
Old May 2, 2013 | 05:41 AM
Robbadodge's Avatar
Robbadodge
Then goes away completely until the next cold start....?
Normal engine sounds. Get a louder exhaust, the ticking will go away.
Old May 2, 2013 | 09:19 AM
Blacknights
Put some oil additive in just as a precaution, it may get rid of the noise within about 50 miles. If you can still hear it after the additive is put in but it is much quieter. Then I have bad news for you, you might need to start budgeting for an engine replacement in a few years.
My engine rod is almost worn out and this is the best I can do from the forums. My engine makes a similar noise, and it is located on the right side of the engine. And I originally thought it is was the exhaust manifold (but I didn't have a leak).
