rear end noise
Old Apr 30, 2013 | 10:44 PM
khen71's Avatar
khen71
Default rear end noise
I have recently started to notice a small whining noise coming from the rear end, normally i would say it is an internal issue but it doesn't make the noise going straight down the road, Only does it when i turn a corner slowly like turning in a parking spot or the same when backing out.
Old Apr 30, 2013 | 10:49 PM
MadisonDakota's Avatar
MadisonDakota
Drain your rear differential fluid. Replace it with Mobil 1 75w90. Pray/Hope that solves it.
Old May 1, 2013 | 07:49 PM
Tom A's Avatar
Tom A
Section Moderator
Do you have a limited-slip rear end. Sometimes, they can make noises and still be fine. Other times, they need some work. The best thing to do is pull the cover off and have a look.
Old May 1, 2013 | 08:45 PM
00DakDan's Avatar
00DakDan
Section Moderator
...and while the cover is off, check the spider gears. The only time they move is when you aren't going straight.
