in-hg vacuum at idle
Old May 3, 2013 | 10:23 PM
tspeed109's Avatar
tspeed109
Default in-hg vacuum at idle
Can someone tell me what there vacuum is at idle. Mine is around 17in-hg vacuum.
2004 Dodge dakota 4.7L engine.
I think my plenum gaskets are bad sucking in warm air causing idle issues.
Replaced map sensor tps fuel injectors ignition coils all 8
I have an electric vacuum gauge hooked up just after the throttle body and it says 17hg vacuum seems a little low right??
Old May 3, 2013 | 10:47 PM
00DakDan's Avatar
00DakDan
Section Moderator
17" is about low normal. What port you're measuring it from can change the reading some too. Try tapping into the brake booster line.
16-22" is pretty much normal. It should be nice and steady.
If you live at a high altitude the reading can change some (lower).
