PLEASE HELP !!! Replaced everything....still intermitent miss real bad
Old May 8, 2013 | 08:10 PM
jaysway007's Avatar
jaysway007
It seams to only do it after it warms up for a minute.....It is not throwing any codes at all now....I have not checked the plugs, but I suspect that the plugs are ok because it runs great and sounds great ,and has a perfect smooth idle and rev until I drive it a little bit.......also I just took it for another ride and this time it ran great for about ten blocks...then ran rough..but it seems like I can get the problem to come and go if I get on and off the gas a little bit...also I have a innovative motorsports open tune obd 2 ot-2 unit...it shows codes and lets me clear them but not much else I will look online and get instructions on testing temp sensor and then report results
Old May 8, 2013 | 08:31 PM
jaysway007's Avatar
jaysway007
WOW !!! I just took a look at where that coolant sensor is located...looks like a real pain in the rear to replace, and hard to check also...I can remove ac comp and get to it easy...but before I do that I wanted to ask... Does that sensor control the dash readout? because if so my dash is reading fine...cold on start up...then gradually rising to operating temp. Is that enough to verify that it is working or do you think that I need to perform actual test on unit itself?
Old May 8, 2013 | 09:22 PM
00DakDan's Avatar
00DakDan
Section Moderator
That sensor does both.
The PCM sends a signal over the CCD bus to the gauge cluster, it's not like older style vehicles.
Old May 8, 2013 | 10:53 PM
DK Pony's Avatar
DK Pony
Some of the other guys on here know a lot more about these particular vehicles than I do. but if you could trace the wires and maybe probe them in a more accessible place. You would check it cold, then at operating temp and compare the two readings, If you have a repair manual for it they usually give an actual resistance value.
http://www.aa1car.com/library/coolant_sensors.htm
O2 sensor is certainly something to check too.
http://www.aa1car.com/library/o2sensor.htm
Personally I would do a plug read and see what color etc. they are. If they are black or smell of fuel it could lead you to a rich condition whereas if they are white or burned it could be lean. At this point you don't know if your engine is rich or lean and it could help with diagnosis
