HELP!! Replacing hub/bearing and spline shaft is stuck
Old May 12, 2013 | 11:27 AM
liam5340's Avatar
liam5340
Default HELP!! Replacing hub/bearing and spline shaft (cv shaft?) is stuck
02 dakota v6 4x4 QC replacing front driver hub and I can't get the spline cv shaft out, it appears to be seized in the bearing, any help on getting it apart?? Please any help is appreciated I need her back up and driving, thanks guys
Old May 12, 2013 | 11:35 AM
00DakDan's Avatar
00DakDan
Section Moderator
I moved your thread into the correct forum.
You have removed the axle shaft retainer nut, right? Try hitting it with some penetrating oil.
Can you get a puller, to remove the shaft?
Old May 12, 2013 | 12:44 PM
jpayne80's Avatar
jpayne80
Keep hub bolted on and hit the cv shaft with a big hammer.
Old May 12, 2013 | 03:21 PM
sxrsil3nt's Avatar
sxrsil3nt
Hit the end of the axle and if it moves you're set. Use heat too if its really stuck.
