2001 dakota 4.7 lean bank one code
Old Jun 1, 2013 | 11:41 AM
dave280zzz's Avatar
dave280zzz
Default 2001 dakota 4.7 lean bank one code
I developed an exhaust leak right where the manifold is attached to engine in oct of last year. Truck ran fine just a little noisy. About a month ago I got in truck and idle was a little rough. I have maybe driven it a couple hundred miles around town since. Decided to check and change spark plugs to clear rough idle. When I changed plugs I noticed the 4 passenger plugs were perfect and the four plugs on drivers side were carboned up really bad. THen I got a code for lean bank one. New here but any help would be appreciated on what could be causing the plugs to burn that way, thanks
Old Jun 2, 2013 | 11:45 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 2nd generation Dakota sub-section.
Old Jun 2, 2013 | 12:50 PM
98DAKAZ's Avatar
98DAKAZ
I don't have the 4.7 and I'm not sure if you have two O2 sensors a side but that sounds like an O2 sensor problem to me just because the problem is on one side.
Have you tried resetting the PCM/computer? How do I reset you ask pull off the Neg battery terminal for 2 minutes then put it back on.
Old Jun 2, 2013 | 12:57 PM
00DakDan's Avatar
00DakDan
Section Moderator
What side has the exhaust leak? I'm guessing the drivers.
Fix the exhaust leak. It should solve your problem.
