battery question
Old Jun 14, 2013 | 05:12 AM
rich1374670x's Avatar
rich1374670x
Default battery question
I recently disconnected my battery to clear some codes. I reconnected the ground and now it is dead. It was fine up to that point. It was only disconnected for 1 hr. The eye is still green. Why did this happen? I am not upset as the battery is the original and its a 03. But a little puzzled.
Old Jun 14, 2013 | 08:49 AM
dakotaff's Avatar
dakotaff
I would recheck all of the battery connections. What's happening, any lights at all, turning over at all, clicks...?
An original 2003 battery should be replaced anyway, I can't see how it would be good anymore. If you have an Advanced Auto near you, order online and use a code below to save a few bucks.
Advance Auto discount codes:
  • $10 off $30+ or $25 off $70+ orders
    • use promo code A124
  • $20 off $50+ orders
    • use promo code ES123
  • $30 off $90+ orders
    • use promo code HUGE30
  • $40 off $100+ orders
    • use promo code TRT41 (or try CCABIN or A124)
  • $50 off $125+ orders
    • use promo code DOW24
    • HUGE50 - $50 off $175
You need to sign in for the codes to work. Offer valid for online orders placed June 11th, 2013 through June 15th, 2013 before 11:59pm ET, using promo code DOW24.
FYI: Your 2003 Dakota is a 2nd Gen Dakota, this is the third Gen section.
Old Jun 14, 2013 | 10:21 AM
kingr00's Avatar
kingr00
By "ground", are you talking about the reconnecting the ground cable to the negative post on your battery? (I assume you are)
I disconnected my battery a few days ago to do some work on the engine and when I reconnected it, I could not get it to connect properly. I could not tighten it enough to grip the post tightly. Because of that, the battery stopped charging and all I got was clicks.
I had to disconnect the negative cable, deform the cable connector and reconnect. After I did this, it has worked like a champ.
Old Jun 14, 2013 | 10:35 AM
sl2racer's Avatar
sl2racer
my 2003 had the same problem. finally figured out the actual battery terminal had separated from the battery. mine was the original battery form the factory.
Old Jun 14, 2013 | 01:07 PM
98DAKAZ's Avatar
98DAKAZ
In the Arizona heat 112+ your average battery life is only 3 or 4 years if lucky.
You would be crazy to own an electric car in Arizona electric cars are dangerous fire *****
Old Jun 14, 2013 | 04:44 PM
Robbadodge's Avatar
Robbadodge
[LIST][*]$40 off $100+ orders
Sorry to hijack here: Need a motorcycle battery, you just saved me $40. Thanks friend!
