Halo headlight wiring?
Old Jun 15, 2013 | 05:03 PM
jacobclif_9's Avatar
jacobclif_9
Default Halo headlight wiring?
I watched a video that shows how to wire them but it looks like you have to turn the lights on as they are wired to the orange lights. Any way to get them so that they are on whenever the truck is, like DRLs
Old Jun 19, 2013 | 06:47 AM
KillerKilgore's Avatar
KillerKilgore
There are several ways. Depending on how much amperage is needed and how clean you want the install.
The easiest cleanest way would be to get a normally open relay that you could bolt on the side of the engine compartment. Then wire that to the accessory fuse. That way when the accessories have power. It would send a little amperage to the relay. Which would cause the relay to engage sending a large amount of amps to the lights.
They make a special fuse just for that purpose. It is a pigtail coming off one side. You would insert the pigtail side of the fuse so that IF the fuse blows, the pigtail has NO power.
