lift kits
Old Jun 20, 2013 | 06:39 PM
chalbert88's Avatar
chalbert88
Default lift kits
Will a lift kit for a 1998 Dakota fit on a 2002? If not, can someone explain why? Thanks for any help.
Old Jun 20, 2013 | 10:57 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 2nd generation Dakota sub-forum.
Old Jun 21, 2013 | 08:49 AM
sxrsil3nt's Avatar
sxrsil3nt
They switched to rack and pinion steering from 2000+.
The 97-99 lift you see won't work cause of that.
Your options for your 02 are (assuming its a 4x4):
-3 inch Body Lift $250
-2 inch Blocks for the rear $150
-2 inch max gain from cranking your torsion bars -free
-3 inch leaf shackle flip for the rear - free
2wd:
-2 inch coil spacers
-1 inch approx gain from v8 springs (assuming you have a v6)
-3 body lift.
All i'm aware of, cheers.
Old Jun 21, 2013 | 01:58 PM
chalbert88's Avatar
chalbert88
So the 97-99 doesn't have the rack and pinion? I'm not trying to sound dumb, I just don't have much mechanical experience.
Old Jun 21, 2013 | 01:59 PM
chalbert88's Avatar
chalbert88
Or experience with Dakotas for that matter.
Old Jun 21, 2013 | 02:43 PM
sxrsil3nt's Avatar
sxrsil3nt
Nope, rack and pinion was only introduced in the 2000+ models.
Old Nov 1, 2013 | 05:13 AM
DurdyGP's Avatar
DurdyGP
My 97 has rack n pinion its 2wd with power steering
Old Nov 1, 2013 | 08:06 AM
sxrsil3nt's Avatar
sxrsil3nt
Sorry I should have been more clear. I believe 2wd Dakotas came with rack and pinion, but 4x4 came with A steering box.
In 2000 4x4 Dakotas switched to rack and pinion as well.
Someone else may be able to confirm this.
