No speedometer
Old Jul 1, 2013 | 03:56 PM
stuttle51's Avatar
stuttle51
Default No speedometer
Have a 2004 Dodge Dakota 3.7 Liter. 176k miles. New to the forum so be gentle I woke a few days ago and had no speedometer. All other functions on the display still work. The check engine, ABS, Air Bag, and Brake light all came on also. I have changed out the ABS sensor in the transmission and differential. Still no change on the lights and speedometer. Also the A/C and heater stopped. Blower will come on at the highest setting but no conditioned air. Any advice would be appreciated.20130701_121936[1].jpg
Old Jul 5, 2013 | 09:15 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 2nd generation Dakota sub-forum.
Old Jul 5, 2013 | 09:40 PM
00DakDan's Avatar
00DakDan
Section Moderator
Hi and welcome to the forums.
Can you pull any codes? Try the "key-dance" if you don't have a scanner.
Truck off. Turn the key on (not start), then off, on, off, and then leave on. Any codes should display in the odometer window.
