No air at vents. Air IS at feet and defrost.
Old Jul 5, 2013 | 11:50 AM
majesticgriffin's Avatar
majesticgriffin
Red face No air at vents. Air IS at feet and defrost.
I just purchased a 98 Dakota. The AC does work but I can not get air to come out at vents. I can change it to blow out at my feet and I can get air out the defrost at the windshield. My first thought is that the blend door is malfunctioned or the actuator for the blend door is bad. After scouring these forums I am wondering if the problems isnt a "mode" door instead. Ive been trying to find pics or at least diagrams for the locations of all actuators and doors but I havent found any. I do know where the recirc door and actuator is at. Its on the passenger side right next to the blower motor. I have checked the door and actuator and they both work just fine. I visually saw the rod attached to the door move when I changed settings on the climate control *****. Like everyone else here any help would be appreciated. I want to check the remaining doors and actuators but I dont know where to look. If I can get my issue fixed I will most definately post my fix with pics here to help future members with their headaches concering this problem. Thank you everyone in advance!
Old Jul 5, 2013 | 11:54 AM
majesticgriffin
I forgot to mention that when I select vents I do hear the air trying to change route and then a faint whomp as if the door did change positions but no air is felt at the vent outlets. Maybe a clogged tubed? i dunno, I am stumped.
Old Jul 6, 2013 | 09:10 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
umm 98 dakota is a 2nd generation dakota, this is the first generation durango section, while the trucks are very similar you should be posting in the dakota section, i will move this thread for you
Old Jul 8, 2013 | 09:35 PM
rpowell's Avatar
rpowell
Don't know if it's the same, but I had an issue like that with my 2003. Had the exhaust manifold gaskets replaced and the mechanic accidentally pulled the little vacuum line off under the hood. Was hard to find, had to reach my arm all around up under the airbox housing that is right by firewall. Found a little vacuum line loose, felt around some more and found where it went. Got cold a/c out of the main vents again.
Hope this makes sense and helps. Freaked me out when I went through it in the middle of a TX summer, but I got it fixed
Old Jul 9, 2013 | 09:48 AM
00DakDan's Avatar
00DakDan
Section Moderator
There are 4 doors.
1. The blend door, cable controlled for temperature
2. A panel/defrost actuator
3. A floor/defrost actuator
4. A recirc actuator
By default, if the system has no vacuum air will come out the defrost.
In order to access these other actuators you'd have to remove the plenum. Make sure they are getting the proper vacuum. If you do a search you'll find lots of information on this forum. 98Dakaz has a link to pictures of his '98.
Good luck.
Old Jul 9, 2013 | 10:10 AM
98DAKAZ's Avatar
98DAKAZ
LINK just click on my sig below
