X-tra Lube Oil Treatment
Old Jul 8, 2013 | 09:30 PM
rpowell's Avatar
rpowell
Default X-tra Lube Oil Treatment
Does anybody have personal usage stories about Bell Performance's X-tra Lube Oil Treatment? Came across some info the other day and was wondering if anybody has used it.
Thanks
Old Jul 8, 2013 | 10:13 PM
RollerRed's Avatar
RollerRed
Cant personally say I have used this brand. But let me ask why you think you need it? Or is it just for kicks kind of thing?
While I am waiting for a bit more cash to roll in so I can fix my plenum gasket I use just plain jane gasket sealer that you can get at walmart/autozone. Just to help thicken up my oil a bit so I don't lose as much. IDK if it even helps but in my mind it does!
Old Jul 9, 2013 | 12:57 AM
98DAKAZ's Avatar
98DAKAZ
All these are a waste of money and do nothing just use regular oil or synthetic oil
Old Jul 10, 2013 | 11:18 PM
rpowell's Avatar
rpowell
I had read through a report comparing friction modifiers/engine treatments and it looked really good.
I only use synthetic oil in my truck and was just wondering if anybody has used it. I'll see if I can upload it or copy & paste here.
Old Feb 16, 2014 | 11:28 AM
roybobo's Avatar
roybobo
Default Questions about X-Tra Lube
I have been using X-Tra Lube for 23 years now. I put it in everything that has a crankcase. I have seen numerous friction tests on this and other products. While there are a few products that seem to be as good as X-Tra Lube, they are more expensive to use. I have never found anything that tested superior to it. It is not designed to stop leaks. It is made from copper and lead dust (soft metals) and fill tiny scratches and grooves on the contact surfaces (hard metals) in the engine or gear box. Left over particles act as microscopic ball bearings between every contact surface. No chemical reactions, no magic tricks.
Old Feb 16, 2014 | 11:54 AM
bigclubs's Avatar
bigclubs
Well, I will date myself with this reply... LoL, but back when I owned a 80 CJ-7 Jeep, I only used Quaker State oil and only changed it 2 times a year. When I had the engine rebuilt the mechanic said the oil passages were the cleanest he had seen. So conventional oil in this case worked great for 10 years of driving. Todays engines are built with better tolerances than this old reliable vehicle, and regular oil is better refined. It all depends on how much you really want to spend for an oil change. Also the need to change the oil every 3000 is in my opinion a waste of money, since I have seen labels in engine compartments stating change oil every 5000-7500 miles.
Old Feb 17, 2014 | 04:50 AM
Dodgevity's Avatar
Dodgevity
Explain how you're using gasket sealer to "thicken up" your oil, or did you mean something else?
Old Feb 17, 2014 | 05:01 AM
Dodgevity's Avatar
Dodgevity
Sounds like a great way to eventually clog oil passageways and also your catalytic converter. Remember Slick 50? That was zinc. Copper and lead are not engine lubricants.
Old Feb 17, 2014 | 09:54 AM
magnethead's Avatar
magnethead
FWIW, we run a very high zinc racing oil in the race motor. Says right on it "not street legal" because the zinc will kill the catalytic in a heartbeat. We dismantle the clean the oil filter every 25 passes and change the oil ever 50. By the end of the year, there's a 1/4" thick layer of zinc at the bottom of the oil pan.
Old Feb 18, 2014 | 09:51 PM
roybobo's Avatar
roybobo
Default X-Tra Lube.
This is an oil additive. It does not go through the converter. (Unless you are pouring it in the gas tank.) I have used this product for over 23 years. It has never created a problem. There is no similarity to slick 50. Copper and lead happen to be an excellent lubrication enhancer and it is easy to prove with a friction machine. If you will remember lead was a lubricant in gas until the converters started going on the cars. Bell Performance has been in business over 100 years. They made the world's first fuel additive in 1909 for the Model T. Google X-Tra Lube and see how many complaints you can find.
