P0700 need a little help
Old Jul 14, 2013 | 03:34 PM
mabradds's Avatar
mabradds
Question P0700 need a little help
Have a 2001 Dakota 4.7 Auto 2WD 15 bolt on tran pan believe its a 45re. have no low & no overdrive P0700 code, replaced output speed sensor - no change. when Advance scanned it they said it showed the output speed sensor & turbo sensor. Open for help
Old Jul 14, 2013 | 04:36 PM
00DakDan's Avatar
00DakDan
Section Moderator
Hi,
It will be the 45RFE on a 4.7.
P0700 is a generic code - not specific. All it does is indicate that a code is stored for the transmission.
What scanner did Advance use? Many can not read transmission codes.
I have never heard of and have no clue as to what a "turbo" sensor is on a 45RFE.
My first suggestion is to get the transmission codes read from a reputable shop, ie: with a DRB (dodge) or from a real transmission shop.
Old Jul 15, 2013 | 08:05 AM
mabradds's Avatar
mabradds
Dan, believe it was a handhel Actron. He said the store"turbo sensor" was same part # on the front of the tranny. For the lockup converter I believe. Thanks
Old Jul 15, 2013 | 10:00 AM
00DakDan's Avatar
00DakDan
Section Moderator
There's an input and output shaft speed sensor on the transmission. Other than that you are opening it up to replace parts.
Still "turbo" means nothing.
I really don't think he has a clue. If they can't give you a specific code, not the generic I would rely on them.
