radiator upgrade
Old Jul 19, 2013 | 05:09 PM
fdrgator's Avatar
fdrgator
Default radiator upgrade
2000 Dakota 4.7 with standard cooling. Is the heavy duty radiator (as used in the trailer tow package) a drop-in replacement? I doubt it, so if not what else has to be changed?
Mine works ok but could use some help when towing in the mountains. I do have an aftermarket trans cooler, which works well.
Old Jul 19, 2013 | 06:05 PM
01dak3.9's Avatar
01dak3.9
If your upgrading the radiator just go ahead and get an aluminum, 3 row radiator, ditch the clutch fan, and put in a 180 t-stat.
Old Jul 19, 2013 | 06:07 PM
00DakDan's Avatar
00DakDan
Section Moderator
It should drop in just fine. It's a little thicker, that's it.
It's Dodge p/n 52028818AD. It actually fits both the 4.7 and the 5.9.
Old Jul 19, 2013 | 08:04 PM
fdrgator's Avatar
fdrgator
Thanks for the replies. One other follow-up question: Is there a reason for ditching the fan?
Old Jul 19, 2013 | 08:24 PM
00DakDan's Avatar
00DakDan
Section Moderator
I wouldn't ditch the fan if you're having trouble in the mountains cooling. If you do consider upgrading the electric fan.
Then again, I wouldn't put in a 180 thermostat either but that's just me. The engine was designed for a 195.
Old Jul 19, 2013 | 09:29 PM
fdrgator's Avatar
fdrgator
Now you've got me thinking. I wonder if the electric fan is working. I'll look into that.
Old Jul 19, 2013 | 10:02 PM
00DakDan's Avatar
00DakDan
Section Moderator
Is your clutch fan working? If you're getting warm it should be roaring.
