a/c help
Old Jul 25, 2013 | 04:29 PM
hanman67's Avatar
hanman67
Unhappy a/c help
i have a 2002 dakoda the air will not change from top [defrosst] too dash or floor. are there any vacum lines or a controler or accuator some wear??i replace the dash controls and no change. can hear it whanting too change but cant HELP......
Old Jul 25, 2013 | 09:19 PM
00DakDan's Avatar
00DakDan
Section Moderator
Hi and welcome to the forum.
Your '02 Dakota has electrically controlled actuators, not vacuum. There is a way to recalibrate the actuators but I can't find it in the factory manual - even though it tells you where it should be it isn't there.
I've heard you can also disconnect the battery for about 15 minutes and then the system will "relearn."
