What's your Dakota's current milage.
Old Oct 4, 2013 | 04:30 PM
  #31
Olmanofthemountain's Avatar
Olmanofthemountain
'00 Dakota QC, 2 wheel drive, 5 speed auto, 4.7, original owner for 13 yrs. Installed fiberglas Tonneau cover when new. Now has 209,6xx miles. At 98,000, began Mobil1 5w30, w/ Mobil Filter M1-204, changed every 5,000 to 6,000 miles. Proactive tire changes with Michelins at 40,000 regardless of tire wear gauge. Filled tires w/ nitrogen and just forget about leakage! Never failed local EPA inspections. All-driving gasoline mileage is about 18 mpg, with 20 mpg into the mountains north. My occupation as a catastrophe insurance damage appraiser, required high mileage to hurricane areas in Florida, Louisiana and Texas, where vehicle dependability was a must. My Dakota has never given me any major mechanical problems, but only recently developed routine maintenance issues for which I now search the Dodge Forums for tips on successful repair methods. Thanks to all the forum posts concerning my worn out fan clutch and the occasional overheating (due to clogged radiator(s)) One dealer replaced 3 radiators at just under 20,000 miles each, due to their choice of red colored anti-freeze! That dealer went out of business. I'm not a mechanic, thus I pay someone else to service my vehicles. But, I like to keep in the loop as to the origins of mechanical problems.
Old Oct 4, 2013 | 06:21 PM
  #32
DK Pony's Avatar
DK Pony
Nevermind.
Old Oct 4, 2013 | 09:44 PM
  #33
2001DodgeMan's Avatar
2001DodgeMan
my 2001 Dakota has about 122k miles on it now
Old Oct 4, 2013 | 10:09 PM
  #34
atthewmartin114's Avatar
atthewmartin114
lol well im not listing everything i have replaced because that will take too long but the original parts as of now are the motor and trans and front dif. everything else including the cab have been replace it has 146k its a 1997 5.2L 8.25 rear with 4.56 gears shackel flip torque bars key 3 in lift. 33x1050.r 15 TSL super swampers costom bumpers front and rear role bar. most current upgrade. i installed a 2500 ram hydro boost system. (brakes work great now !! stops my 30 foot tri axle on a dime!!) also working on converting from iac to maf but im thinking its going to be a pita.
Old Oct 5, 2013 | 12:12 AM
  #35
Kyguylal's Avatar
Kyguylal
Right now, 2000 3.9L 2wd has 78k on it. 5-speed
Old Oct 7, 2013 | 12:40 PM
  #36
spacetrace33's Avatar
spacetrace33
New Member
98 dakota 3.9 auto, It reads 286000, but it's actually higher. I think when the speed sensor went out, it stopped counting the miles. If that's the case, it's probably over 300,000. Aside from standard maintenance, had entire front end replaced, front wheel bearings, starter, and everything that the drive belt wraps around. It needs some new suspension front and back, and body panels, and maybe engine is getting a little worn, but it's good ole' reliable, for now.
Old Oct 7, 2013 | 03:52 PM
  #37
DakCC4x4's Avatar
DakCC4x4
Ive got about 123k on my 04 Dak 4x4 4.7 auto. Replaced front d-shaft, water pump, driver side brake caliper and pretty much just regular maintenance besides that. Bought it with a little less than 100k on it a few years back.
Old Oct 7, 2013 | 04:17 PM
  #38
DakCC4x4's Avatar
DakCC4x4
Hey atthewmartin114 you got some pics of your truck and how you did the do hydro boost swap?
