Transmissions, Gearing and RPM
Old Nov 19, 2024 | 03:52 PM
  #21
TJM123's Avatar
TJM123
Default help new to forum
I have a 98 dodge Dakota v6 two wheel drive v6 transmission is a 46re just replaced it have these codes pop up
P0753 overdrive solenoid circuit
P1762 Tran voltage rly circuit
P0743 TCC solenoid circuit
any ideas where I should start also it start in 2nd or 3rd gear and it says transmission is running hot
Old Nov 19, 2024 | 03:59 PM
  #22
What year was the trans donor?
Old Nov 19, 2024 | 04:02 PM
  #23
TJM123's Avatar
TJM123
I believe a 2000
Old Nov 19, 2024 | 04:33 PM
  #24
Originally Posted by TJM123
I believe a 2000
There is part of the problem. The electronics changed in 00..... so the PCM is getting readings it doesn't understand... That's why the trans temp light is coming on. You *should* be able to just change the electronics, and be good to go. "Should" being the key word there. If you had a shop do it, have a chat with 'em.
Old Nov 19, 2024 | 04:41 PM
  #25
TJM123's Avatar
TJM123
What electronics exactly do I change?
Old Nov 19, 2024 | 04:43 PM
  #26
Governor pressure sensor and solenoid. Need the old style retainer for them as well. (if you still have your old trans, can grab it from there, I would go with new electronics though.) You *might* have to change the O/D and TCC solenoid set as well, the connector on those may have changed too. Those are more fun to get though. Videos on youtube for that exercise.
Old Nov 22, 2024 | 07:24 PM
  #27
TJM123's Avatar
TJM123
Just curious at what speed should my vehicle shift into fourth gear 98 dodge dakota 2 wheel dr
Old Nov 22, 2024 | 08:47 PM
  #28
Right around 42 MPH.
Old Nov 22, 2024 | 08:51 PM
  #29
TJM123's Avatar
TJM123
Well that's not good mine for some reason will not shift into 4th would the transmission speed sensor have anything to do with that?
Old Nov 22, 2024 | 09:00 PM
  #30
TJM123's Avatar
TJM123
I can also say that I no longer have codes that pop up but my engine light is on abs light and transmission hot light is on even though I know it not running hot
