Park idle surges?
Old Aug 8, 2013 | 05:02 PM
Jeremy98dakota's Avatar
Jeremy98dakota
Default Park idle surges?
I have noticed when my truck is warm and it is idling in park the rpms surge. I know it is a sensor on the throttle body(MAP, IAC, TPS) i just dont know which one. I havn't noticed it when i am driving.
Old Aug 8, 2013 | 05:05 PM
Jeremy98dakota
i dont know if it would matter but i did just but an 8" sub in my truck that is running on a 820watt amp. Do you think it could be drawing to much power?
Old Aug 8, 2013 | 05:59 PM
Jeremy98dakota
Another thing i noticed is it seems to only do it when i put it in park after driving it.
Old Aug 8, 2013 | 10:07 PM
98DAKAZ's Avatar
98DAKAZ
unplug the 820 watt amp for a day or two and see what happens.
820 watt amp? Why?
could be the alternator is about worn out so the 820 watt amp is taxing it in idle
Do you have a high amp battery for the 820 watt amp?
I'm not the best at this stuff so its my guess
Old Aug 8, 2013 | 10:16 PM
Jeremy98dakota
surprisingly a 400 watt amp wasn't enough to power the sub and the 820 was the next size Walmart had. and i may have to try that.
Old Aug 8, 2013 | 10:24 PM
98DAKAZ's Avatar
98DAKAZ
I found this it may help
http://www.termpro.com/asp/pubs.asp?ID=117
I think the OEM alternator only puts out 112 amps max some have a higher output alternator around 135 amp I think but you can get them higher
Old Aug 8, 2013 | 11:14 PM
98DAKAZ's Avatar
98DAKAZ
How old is your battery?
How many amps?
Are your battery cables in good shape no corrosion?
Did you ground the amp with a separated ground of its own?
Are the cab grounds in good shape?
Some things to check on
Old Aug 9, 2013 | 05:00 PM
Jeremy98dakota
How many amps?
Battery is lest then a year old and im not sure on the amps.
battery ends are new and no corrosion that i can see
i ground the amp on the seat bolt
cab grounds?
