Dakota overheating badly
Old Aug 13, 2013 | 10:39 AM
  #21
98DAKAZ's Avatar
98DAKAZ
I use just a spray nozzle set to a strong stream every year to get the bugs out.
I have also gone to one of those self car wash booths that have a power wash sprayer and it didn't do any damage
Old Aug 13, 2013 | 11:18 AM
  #22
00DakDan's Avatar
00DakDan
Section Moderator
Originally Posted by stealth13
How does this fin comb work?
It's just like combing your hair. You just start on an undamaged section and move the comb slowly through the damaged areas. It bends the fins back straight.
It'll also scrape off the bug carcasses.
It's a cheap tool, less than $20 for a "universal" one.
If you do use a pressure washer just keep the pressure low enough so you're only taking the bugs off.
Old Aug 13, 2013 | 11:37 AM
  #23
stealth13's Avatar
stealth13
Ok I can try that then, hopefully the comb can lift the fins that are squished in?
Old Aug 13, 2013 | 12:24 PM
  #24
00DakDan's Avatar
00DakDan
Section Moderator
If it won't, use a plastic putty knife to work them up individually. Be careful about using anything metal - you can puncture the condenser.
Old Aug 13, 2013 | 03:06 PM
  #25
98DAKAZ's Avatar
98DAKAZ
This one looks good $11.99
http://www.jegs.com/i/Allstar+Perfor...FSU6QgoduTgAng
