Fluid on rear tire?
Old Aug 18, 2013 | 12:21 PM
Ryan Passini's Avatar
Ryan Passini
Default Fluid on rear tire?
Any idea what this is? New to anything involving rear axles.
It doesnt seem fresh. I touched the stuff on the tire and it didnt wipe off.
https://dl.dropboxusercontent.com/u/...3/reartire.jpg
Old Aug 18, 2013 | 01:20 PM
00DakDan's Avatar
00DakDan
Section Moderator
Gear oil? Leaky axle shaft seal.
Old Aug 18, 2013 | 01:22 PM
Ryan Passini
Thats what I was thinking...
Is this video basically how its done?
except I have disc not drum.
Also, do I need that special tool to push it into place?
Old Aug 18, 2013 | 01:32 PM
Brian in Tucson's Avatar
Brian in Tucson
Does it smell like rotten onions? That's gear oil.
Otherwise it could be a leaky caliper.
Old Aug 18, 2013 | 01:43 PM
Ryan Passini
rotten onions? lol. I dont know....I need to replace the caliper anyway. So once I take it apart I'll check
Old Aug 18, 2013 | 02:29 PM
sxrsil3nt's Avatar
sxrsil3nt
Check the wheel cylinder too, could be brake fluid.
Old Aug 18, 2013 | 03:20 PM
00DakDan's Avatar
00DakDan
Section Moderator
Looking at it again, it seems to be slightly "damp" near the caliper and then over the brake shield.
Calipers can leak too.
Old Aug 18, 2013 | 07:46 PM
Tom A's Avatar
Tom A
Section Moderator
If it's brake fluid, you'll be able to hose it off with plain water. But it looks like gear oil to me.
Old Aug 18, 2013 | 07:57 PM
Ryan Passini
It was gear oil. that seal was destroyed.
Too bad it took me 4 hours to get the new caliper to stop leaking by the banjo bolt. what a pain in the ***.
