Crankshaft Sensor?!? could it be??
Old Sep 9, 2013 | 10:19 AM
Mr.D's Avatar
Mr.D
Question Crankshaft Sensor?!? could it be??
Gotta 01 Dakota 4.7 thats not starting for me! One day, ran to the store, wen i came out it wouldn't start. 5 min later it started right up. Now i cant get it started at all. Can hear my fuel pump working, my grounds are clean and secure. I just changed my plugs about 3 weeks ago and it ran fine. Seems like im not getting any spark. Plenty of juice to crank it, but no start!! I read on another thread that it might be my Crankshaft Sensor or Cam Sensor. Could the sensors be the problem? Im stuck and need hepl!! Thanks in advance
Old Sep 9, 2013 | 11:00 AM
00DakDan's Avatar
00DakDan
Section Moderator
Did you check for codes?
Starting with the key off, turn it to RUN (not start), off, RUN, off, then leave it in RUN. Any codes will display in the odometer window.
