Big Mikes 98 Dakota 2.5 Reg Cab 2wd Build Thread
Old Nov 16, 2013 | 12:46 PM
  #51
Bigboi407's Avatar
Bigboi407
I looked up the SCT Tuner, but couldnt find one for the 2.5 dakota/jeep engine, i spoke to my brother and he says even a PnP & a 3 angle valve job together wouldnt be much gain at all on since im not going all out 100%, i do want to smooth out the intake, theres alot of excess material that can be removed easily
Next up, i need to get my injectors cleaned
Old Nov 17, 2013 | 12:46 PM
  #52
DurdyGP's Avatar
DurdyGP
I do have to say my motor is stock I put the Banks headers on an wow its quite n the pick up when I hit the gas is so much better well worth it now I just need to figure out this P505 code I all ready replaced the iac 2x
Old Nov 19, 2013 | 04:58 AM
  #53
98DAKAZ's Avatar
98DAKAZ
I just found this 2.5 rebuild he did a good job but goofed up not over boring the thing the 2.5 needs more power only way is install the biggest pistons you can get a 4.0 throttle body some head work and headers by Banks their is a number of small things that can be done to help also like a Hot coil and good plugs some better injectors also check the belt tensioners they tend to go dry and bog things down always install new ones.
The Link
Old Nov 19, 2013 | 05:30 AM
  #54
98DAKAZ's Avatar
98DAKAZ
This pic will show you how restrictive the stock exhaust is look at that angle just horrible no flow to the stock ones at all.
Old Nov 21, 2013 | 10:55 AM
  #55
Bigboi407's Avatar
Bigboi407
Old Nov 30, 2013 | 07:28 PM
  #56
Bigboi407's Avatar
Bigboi407
Went to the Junkyard today, i got a 4.0 Throttle body off of a 2000, i also pulled 2 head bolts so i can put my head on tomorrow, i also pulled Alot of stuff for my 91 Accord, so ill be quite busy this week
i still need to find an electrical plug for the Fuel injector so i can run the injectors to clean em out
Old Nov 30, 2013 | 08:58 PM
  #57
98DAKAZ's Avatar
98DAKAZ
If you mean head bolts you are supposed to use new head bolts every time the head is removed.
Are you talking bolts that attach to the head like for mounting the air hat?
Old Dec 1, 2013 | 10:26 AM
  #58
Bigboi407's Avatar
Bigboi407
I have a brand new set.... but the head doesnt have Dowels, so i need to use 2 old head bolts to align the head
Old Dec 1, 2013 | 10:54 AM
  #59
98DAKAZ's Avatar
98DAKAZ
Cant wait to see it done
You should list everything you did to it like a build sheet
It will help out other 2.5 engine owners watching have you seen the number of people that have looked at your thread almost 2k
Most 2.5 engine owners keep quiet on this forum as its mostly V6 or V8 owners and they tend to slap 2.5 engine owners down.
I on the other hand don't care I like my 2.5
Old Dec 1, 2013 | 12:07 PM
  #60
Bigboi407's Avatar
Bigboi407
Well these other ppl need to chime in if they have other questions/concerns or suggestions, damn the 4 cylinder haters, if its what you have and what you like, whats others opinions matter??
ill even add something which may catch some dirty comments...
I own several other vehicles, i LOVE 4 cylinders, and IMO one of the best 4 cylinder engines in existence is Hondas D16Z6 its 1.6 Liters, 16 valves, SOHC, you can go High Compression with it... 14:1 or u can put forged 8.5:1 pistons in it and boost it to 15-25psi (depending on build) Their Runner up in my book would be a B16A, with very little modification it can rev up to 11,000 RPM's
1994 Suzuki RF900RR
1986 Honda Civic Si hatchback
1991 Honda Accord LX
