Evap leak code
Old Sep 18, 2013 | 05:57 PM
dutchpole2's Avatar
dutchpole2
Red face Evap leak code
So I have a P0442 code on an 02 Dakota V6 and I have checked the system from the purge valve to the canister with inspection and starting fluid. No change in engine speed. So all that's left is a flooded canister or bad gas cap, correct??
Is there a way to check the canister??
Could it be a faulty ECM ??
If I clear the code the truck runs fine until the light comes back on, then it is sluggish with poor MPG.
Thank you all for any input!!
dutchpole2
Old Sep 18, 2013 | 06:26 PM
magnethead's Avatar
magnethead
I know my cap failed state inspection, but i put it back on because it's a locking type....honestly, I've never felt a performance hit due to it.
Old Sep 18, 2013 | 06:43 PM
01SilverCC's Avatar
01SilverCC
When I had that code it was a bad Evap Systems Leak Detection Pump. But I had been in a wreck which broke the pump somehow, it is mounted on the bottom of the battery tray and I was hit in the left front corner...Try a new gas cap first, much cheaper and less trouble. I bought a Stant cap at Advance, it works fine and cost way less than OEM Mopar.
Jimmy
