98 Dakota 5 speed no clutch
Old Sep 19, 2013 | 07:59 PM
BlackTrim211's Avatar
BlackTrim211
Default 98 Dakota 5 speed no clutch
So here's the deal boys my 98 Dakota 5.2 5 speed had a new clutch kit master / slave cyl set up put in. Everything was done to the book now I have no clutch at all. Any help would be great.
Old Sep 19, 2013 | 08:23 PM
00DakDan's Avatar
00DakDan
Section Moderator
What did you use for the master/slave? Aftermarket?
Make sure there are no fluid leaks. If none, it's likely air in the system.
Old Sep 19, 2013 | 10:51 PM
BlackTrim211
Everything is full, no leaks and fully bleed.
