Towing Questions...
I agree with dodgeramguy85, depends where you rent the dolly from, that may be your biggest problem. About 15 years ago we went to u-haul with a Dodge Ram to get a dolly and tow a 57 Chevy from NC to PA, and they said the Ram was not big enough, but we convinced them. Also extra charge for state to state rental, unless you bring the dolly back to the original store.
I have a 2000 3.9 V6 and am going to pick up a new car. I had planned on driving it back but it's a race car and it would be better to tow even though it is street legal.
It dawned on me it's FWD so I could use a dolly.
I can't seem to find a real towing capacity number for this truck. It's a 2000 V6 "Sport" model. Single cab. It is a 5 speed manual. Will this tow a dolly and car? The car is a 2005 Mazda3, specs say it weighs 2900 - 3100lbs.
Would I struggle? I would be getting the car in TN and taking it back to GA. So I think there would be some hilly terrain. Would I run into issues with either making it up hills or going down steep hills with a dolly?
What type of hitch should I get for the truck?
Since you have the 3.9L V6 I would imagine you would be in 3rd gear more, but you should be able to stop about the same. If you take it easy I think you would be ok. 3000+ pounds is definitely taxing it, my truck is rated at 2,000 lbs for towing and I tend to push that from time to time but I never feel like I am out of control or overwhelming the truck. If you had the automatic I would say no way, with the manual trans you should be fine.
I had to to pick up a 20' rental HD flat bed trailer for my school. The trailer itself weighed something around 3,000-4,000 lbs. I had a 2004 Durango with a Hemi in it (towing capacity at 6.5k I think), they said I could tow it but wasn't allowed to load anything on the trailer with the Durango towing...
There are routes you can take to make it less hilly. You can cross over to 75 from Jasper pretty easily. I guess it depends how far NE GA you start from.
With your light load, having a concern to tow something would leave me concerned you'd drive it at all. If you trust your truck on any trip, you can trust it on this one.
