02 Dakota Caliper bolts/pins
Old Oct 15, 2013 | 08:21 PM
sbrain45's Avatar
sbrain45
Unhappy 02 Dakota Caliper bolts/pins
Putting new frnt break calipers on and one bolt hole stripped. Put in an oversisized bolt (went in crooked too ugh) then the other bolt hole stripped. Has anyone ever put two oversized bolts in one caliper?
Thanks!!
Old Oct 16, 2013 | 08:00 AM
Welcome to DF! You can always to drill and re-tap to the next size bolt. Be sure to use the equivalent strength of bolt. Moving this to the 2nd gen Dakota section so others can assist.
Old Oct 16, 2013 | 08:21 AM
roberttyrrell714's Avatar
roberttyrrell714
Default I don't care how fast it goes, it has to stop
As previous poster stated I'd drill/tap(which requires machining it straight) or buy a new caliper. If it's an off road vehicle that's up to you. When it comes to brakes and the safety of you/others(family/fellow drivers) I don't mess around. If you have a fatality crash just modifying your brakes could put at fault whether it was the REAL prob or not.
Calipers are cheap enough to replace. safety first.
Old Oct 16, 2013 | 11:01 AM
magnethead's Avatar
magnethead
I have both on one side and one on the other.
Old Oct 16, 2013 | 12:04 PM
Brian in Tucson's Avatar
Brian in Tucson
snip!
Old Oct 16, 2013 | 12:55 PM
00DakDan's Avatar
00DakDan
Section Moderator
I don't think he means a bolt on the caliper. More likely it is the steering knuckle that has the stripped holes. The caliper pins screw into it and strip easily.
Old Oct 16, 2013 | 01:40 PM
01SilverCC's Avatar
01SilverCC
Advance sells a caliper slide pin with oversized threads for use in stripped holes:
http://shop.advanceautoparts.com/web...archTerm=13894
I have one on my truck, I was sure glad they had it in stock that day. Part #13894 in the "Help" section of the store. Works like a champ. I think it would be fine to use 2 oversized pins in one caliper but the instructions said not to re-use an oversized pin on any later brake repairs.
Jimmy
Old Oct 16, 2013 | 02:48 PM
98DAKAZ's Avatar
98DAKAZ
You know why they strip out/jam up correct?
Because most don't make sure the caliper piston is pushed all the way in and all pressure is released before they install the caliper.
If you don't do that the caliper will want to go in crooked during install making alignment of the slider pins a hard project causing stripped out slider pin holes.
Old Oct 16, 2013 | 05:43 PM
sbrain45's Avatar
sbrain45
Yes this is correct. The caliper is fine but the bolt holes in the knuckle stripped out. Just wondered if anyone has put 2 oversized pins in one caliper? or one steering knuckle...thanks all!
Old Oct 16, 2013 | 07:13 PM
magnethead's Avatar
magnethead
yep, I have 2 on one side and 1 on the other. I'm in need of another brake job, and if $$ allows, I'm going to swap the entire knuckle and front brake package for the 04 package.
