Front Wheel Bearing and ABS...
Old Oct 23, 2013 | 08:52 PM
anjp's Avatar
anjp
Default Front Wheel Bearing and ABS...
My truck is a 2WD 2004 v6 Dakota with 85,000 miles. I need to replace the front wheel bearing assembly. Not just the bearing, but the whole hub assembly.
I'm comfortable with the job, I'm just having a bit of a time ordering the correct part. I'm looking at rockauto.com and it looks like I have 3 options for parts.
A- 4wd w/ 4 wheel ABS
B- 2wd w/ 4 wheel ABS
C- 2wd w/ 2 wheel ABS
It's 2WD so option A is out. But I'm not sure if I have 4 wheel or 2 wheel ABS. Is there an easy way to check? It's a newish truck to me so I haven't driven it through a winter season (ice) yet.
And it doesn't look like the parts are interchangeable. The 4 wheel ABS assembly has some sort of gearing on the back while the 2 wheel ABS bearing is just smooth. I put the truck up this afternoon but couldn't get the rotor off to check the bearing assembly. I have work the next few days so didn't want to get too deep into it until I order the hub assembly and am ready to change.
So, ABS. What do I have and how to I make sure I order the correct bearing assembly? Cheers.
Old Oct 23, 2013 | 09:47 PM
00DakDan's Avatar
00DakDan
Section Moderator
Did you see any wires going into the hub? That would be one clue you have 4 wheel ABS.
Another option is to follow the lines from the master cylinder. Check the attached pic. If you see that you have 4 wheel ABS.
You can also email dodge for a build sheet. That'll tell you. Follow this link:
https://dodgeforum.com/forum/2nd-gen...-my-truck.html
File Type: pdf
Old Oct 23, 2013 | 09:55 PM
anjp's Avatar
anjp
Thanks for your help. I didn't see any wires going to the wheel, only the break line. I'll check the master cylinder tommorro. Thanks for the info.
