dodge dakota no spark to the spark plugs coil is good help
Old Oct 30, 2013 | 01:33 AM
fastfreddie688's Avatar
fastfreddie688
Default dodge dakota no spark to the spark plugs coil is good help
i have a problem with my truck the coil shows spark but the wires going to each plug they are not getting spark i replaced the crank position sensor
and still the same problem just was driving down the road and it stalled out and would never start again ..could the pick up coil cause this problem.
sure could use some help with this
Old Oct 30, 2013 | 05:40 PM
fastfreddie688
Default coil good no spark to the plugs???????????
could it be the pick up coil,,or what else would cause this problem
Old Oct 30, 2013 | 10:14 PM
djibara's Avatar
djibara
What year and motor do you have in it that would help
Old Oct 31, 2013 | 01:49 PM
fastfreddie688
Default no spark to plug wires,coul has spark
1999 dodge dakota motor is 3.9 liter magnum
Old Oct 31, 2013 | 10:00 PM
djibara's Avatar
djibara
Also check camshaft position sensor
Old Oct 31, 2013 | 10:26 PM
volaredon's Avatar
volaredon
same thing as pick up coil mentioned above
and YES it could very well be the distributor pickup causing it to not start
Old Nov 1, 2013 | 11:46 AM
fastfreddie688
there is no cam shaft position sensor on this truck...how do you check the pick up coil with a tester on ohms thanks
Old Nov 1, 2013 | 07:07 PM
fastfreddie688
when i test the pick up coil i get a reading of 18000 does this mean that it is a good reading or a bad one.....
Old Nov 2, 2013 | 09:17 AM
volaredon's Avatar
volaredon
look at post directly above this one cam sensor and distributor pickup = SAME THING
18000 ohms=BAD
Old Nov 2, 2013 | 04:41 PM
fastfreddie688
Default no spark to plug wires coil has spark
well i replaced the crank sensor the pick up coil dont no what else to do i am stumped only thing to do now is change the pcm,,well if any body has any ideas
let me know it would be greatly appreciated
