Heater Odor
Old Nov 1, 2013 | 09:44 AM
richard.a.morgan's Avatar
richard.a.morgan
Default Heater Odor
I get a slight anti-freeze odor from heater. No wet floor. Where is the heater air intake? Maybe coming from engine compartment like when someones catalytic farts or diesel gets in front.
Old Nov 1, 2013 | 09:48 AM
richard.a.morgan
2003 Dodge Dakota Quad Cab.
Old Nov 1, 2013 | 10:13 AM
00DakDan's Avatar
00DakDan
Section Moderator
The air comes in from the cowl, passenger side.
Here's a thread you might find interesting:
https://dodgeforum.com/forum/2nd-gen...ore-leaks.html
Old Nov 1, 2013 | 10:14 AM
Vanme's Avatar
Vanme
Hey, I'm from another forum but jumping around I just saw your post. OK, I'm a jeep guy rather but they all work the same.You don't see antifreeze in the floor because the heater core is inside a plastic tray. Keep reading. With the engine hot, divert the fan flow to the windshield, then turn the fan ON to the first speed only while taking a close look to the windshield vents. If you see a little smoke-sigarret-like-vapors coming out....most likely your heater core is worn out/cracked.. It is located behind the dash board on the passenger side and let me tell you, if you live in the cold areas you better get to work in it ASAP because you are gonna have to remove the dashboard to get to it and is no easy task. It happened to me in my Grand Cheroke.
Old Nov 1, 2013 | 10:29 AM
richard.a.morgan
Vanme: No smoke at all. I presume it is EXTERNAL fumes coming in the cowl. I had the timing chains and tensioners replaced a short time ago. Thinking I may have a small leak in engine compartment somewhere and smell is migrating into the cabin.
Old Nov 1, 2013 | 10:37 AM
98DAKAZ's Avatar
98DAKAZ
That usually means your heater core has a pin hole in it and a small amount of antifreeze is leaking in the HVAC box.
You usually don't get the smell from the engine compartment unless all the hood seals are bad or missing altogether then it can get sucked into the cab.
If you have a big hole in the firewall then that can happen
Old Nov 1, 2013 | 10:43 AM
richard.a.morgan
Thanks. I'll give it a good look.
Old Nov 1, 2013 | 10:44 AM
98DAKAZ's Avatar
98DAKAZ
I don't recommend any kind of radiator/heater core seal in a can that's bad crap... don't use it.
I have never had a heater core leak but have always wanted to know if bypassing the heater core and then poring that stuff just in the heater core would work but I think most need the heat to work.
That way you are not contaminating the rest of the engine and cooling system.
If not that would make a great product
Old Nov 1, 2013 | 11:04 AM
Vanme's Avatar
Vanme
Old Nov 1, 2013 | 02:14 PM
deck60's Avatar
deck60
thats how mine started and over the next few months it looked like my vents were smoking
the fluid will actually go out your vent for the ac you will see coolant under your truck there not the carpet as you would expect
I just did mine here are some tips take the front seat out this will give you the extra room you need
this is no fun task but doable if your temper starts getting to you walk away
I have been told by many use an oem core you wont regret it they are really suppose to last longer
this must be a weak point because now i have to do it on my 03 ram I think i will get good at this before winter hits
