What the crap?
Old Oct 14, 2005 | 10:52 PM
horatio102's Avatar
horatio102
Default RE: What the crap?
Interesting. How do you adjust compression ratio via PCM when there isn't electronically variable valvetrain? If the valves were actuated by electical impulses, you could open one sooner, or keep it open longer, to drop CR, but otherwise you're stuck with Volume max divided by Volume min.
What they did was pull timing and fiddle with the curve.
Old Oct 15, 2005 | 12:42 AM
zinnmaster's Avatar
zinnmaster
ur right horatio. i think what i was trying to say is what horatio said sorry once again. my first post was filt with wrong info so far 0 fo 1
Old Oct 15, 2005 | 02:59 AM
brandoncrone's Avatar
brandoncrone
The 45RFE trans controller is flashable to make it into a 5 speed auto, and in up coming years will be made into a 6 speed auto via the new program for the trans controller. I'm not sure ow you go about obtaining the flash. But the 45RFE trans are the same used in the Durango, Dakota, Ram and Grand Cherokee.
ORIGINAL: yrkdakota
DAN what is the 5th gear flash for the 45's about? Can you tell me more [:-]
I think the death flash only affect 98-01 rams.
Old Oct 15, 2005 | 08:52 PM
horatio102's Avatar
horatio102
ORIGINAL: zinnmaster
You've got a better avatar though.
Old Oct 15, 2005 | 09:13 PM
zinnmaster's Avatar
zinnmaster
I do what i can.
