question about bypassing a/c compressor
Old Nov 24, 2013 | 04:35 PM
nickanosh's Avatar
nickanosh
Default question about bypassing a/c compressor
I want to know if it's possible to bypass the a/c compressor in my 2003 Dodge Dakota 4.7 does anyone have any info on this?
Old Nov 25, 2013 | 12:30 AM
moe7404's Avatar
moe7404
i have seen a plate that mounts a bearing and sleeve to take the place of the compresser. but was for my 3.9. i saw it at summit. it might be the same as my 3.9 or not. hope that helps.
Old Nov 25, 2013 | 11:51 AM
magnethead's Avatar
magnethead
No the 4.7 is different. Not sure how the delete functions. Why are you removing the compressor?
Old Nov 25, 2013 | 12:39 PM
sxrsil3nt's Avatar
sxrsil3nt
In terms of the physical set up I know you need to buy a shorter belt, or buy a bracket with a pulley on the end to mimic the AC pulley... seen them on RockAuto.
For the electrical aspect I'm not sure. You may get a CEL for not having the connector attached. There may be a trick around this like installing a resistor or something but I still think a signal would need to be set to the PCM so you may need a reflash IF it does throw a code. The plug could simply be the power AC on/off switch.
Old Nov 25, 2013 | 01:33 PM
magnethead's Avatar
magnethead
electrical is just the A/C clutch. PCM doesn't check it for a status answer i don't believe.
Old Nov 25, 2013 | 01:42 PM
sxrsil3nt's Avatar
sxrsil3nt
I would think the same thing too, but just to be safe I thought I might mention it.
So the physical setup would be the only thing to worry about. Should be pretty straight forward.
Flippin autocorrect.
Old Nov 25, 2013 | 04:34 PM
magnethead's Avatar
magnethead
I don't see the purpose in removing it. with the clutch disengaged, nothing is turning, the pulley is just turning on it's carrier bearing.
Old Nov 25, 2013 | 04:53 PM
00DakDan's Avatar
00DakDan
Section Moderator
Maybe his compressor seized, or the bearing on the clutch. I had that happen a few years back.
The '00 parts book list the same belt number 53032125AB whether it has a/c or not.
I don't believe it.
Old Nov 25, 2013 | 07:09 PM
dodgeramguy85's Avatar
dodgeramguy85
I unplugged mine in my 98 cause I could feel it drag the motor down when it kicked in.
This guy just routed his belt different
If you dont like that idea you could spend the 60.00 on a bypass pulley.
Old Nov 25, 2013 | 08:47 PM
magnethead's Avatar
magnethead
I like that idea.
