3.92 Rear End With Magnum 3.9
Old 12-13-2013, 12:20 AM
Josh17's Avatar
Josh17
Josh17 is offline
I appreciate that tid-bit there, but she's a five speed. I don't want to go as far as 4.56s yet I still have to go to college haha. Also any input about doing the axle flip and leveling kit ? I could also just change the gear and not the axle I just haven't found the gear by itself yet.
Old 12-13-2013, 02:03 AM
magnethead's Avatar
magnethead
magnethead is offline
gear setup is a meticulous process to do on your own and risk not doing it right. They usually run $250-$350 depending on brand, then 3-4 install hours on labor. My 4.10's were 1K out the door.
I was just saying that 4.56's will bring a V6 up to the V8 level of torque, but at the grave loss of fuel mileage due to higher RPM. Most of the ram guys go to 4.56's because they have a tall OD and tall tire that makes it work. If I was race-only, I'd go to 56's or maybe even 88's in a heartbeat. What i'm going to do instead is keep the 4.10's and run a 26" slick for a 5.00 effective ratio or 24.5" slick for a 5.18 ratio, and just change tires at the track. I can use a stock 15" wheel from the rimyard/junkyard for $35 a piece and pick from two Mickey Thompson tires- #'s 3015 (24.5 x 8 - 15, $203 each) , or 3052 (26 x 8.5 - 15, $183 each). That will also drop the back end down, helping to get some weight transfer to where there's no static weight at.
But I have to get the axle locked up first. Not looking forward to another $800 bill to put a lunchbox locker in the diff carrier.
Old 12-13-2013, 02:45 AM
Josh17's Avatar
Josh17
Josh17 is offline
That was very informative. Thank you !
Old 12-13-2013, 07:54 AM
magnethead's Avatar
magnethead
yea, the shop that I use charges more, but he used to work at a mercedes dealership and has a whole rap sheet of experience. Now he runs an off-road shop in Dallas. I forget what his labor rate is since we get a *slightly* lower rate on our racing stuff, but it's still 3 digits an hour.
I have nitro gears in mine, a quality but low cost brand. USA standard is another such company.
The 4.10's for the chry 8-1/4 are $190
The 4.10's for the chry 9-1/4 are $260
The lunchbox locker for the chry 8-1/4 is $450
The lunchbox locker for the chry 9-1/4 is $480
Old 12-13-2013, 07:00 PM
Josh17's Avatar
Josh17
Josh17 is offline
I'm guessing I have the 8-1/4 ?
Old 12-13-2013, 07:25 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Dodge Forum Moderator
The easy way to tell, count the cover bolts. If you have 10, it's the 8 1/4.
If you have 12, it's the 9 1/4".
Old 12-13-2013, 07:54 PM
Tom A's Avatar
Tom A
Tom A is offline
Section Moderator
From what I know about you, you would have no trouble at all installing a lunchbox locker yourself, assuming you currently have an open rear diff. I've done several of them myself (Lock-right, Spartan, and some other piece of crap I can't remember the name of) and I can say that if it takes you more than an hour, you're doing it wrong. You don't even need to remove the carrier from the truck. Just pull the cover and the axles (again, assuming you have a stock open carrier now).
Of the three, I would recommend the Spartan for ease of installation. The Spartan and the Lock-right were both trouble-free once installed, but the Spartan was easier and seemed a little stronger just by visual inspection.
Old 12-13-2013, 09:41 PM
magnethead's Avatar
magnethead
Since I have the 4.10's already, the ring has to come off for the cross-pin to come out. Otherwise you bet I'd be doing it at home. >.>
Old 12-13-2013, 09:44 PM
Tom A's Avatar
Tom A
Tom A is offline
Section Moderator
Ah, bummer. It can still be a DIY job, but that certainly makes for a lot more work.
Old 03-25-2018, 01:18 PM
Frankie Cipolla's Avatar
Frankie Cipolla
Frankie Cipolla is offline
Default i need a rear end
I have a 1997 dodge Dakota with a gear ratio of 3.92..... I need help finding a new one I tried everywhere
Quick Reply: 3.92 Rear End With Magnum 3.9
