1998 dakota 2.5 Bored .060 over, Trouble Code P1391
Old Dec 24, 2013 | 11:06 PM
  #51
magnethead's Avatar
magnethead
Originally Posted by Bigboi407
According to some of the posts i saw for P0304, some guy argued that mechanical issues could be intermittent, How that works IDK
Ignition coil is $29.99
Dizzy cap is $9.00
Rotor is $9.00
Aaand idk if the ECM going bad is a possibility, but i need to solve this ASAP before that truck gets pulled out of their yard, they are VERY hard to find
EDIT: Just did a Fuel pressure test, it was 50psi, but was bouncing between 47/48 to 50psi in idle, then if i pushed the throttle, it would stabilize and stay steady at 50psi
anything over 40-45 is acceptable I'd say. Our mechanical injection runs at about 50 PSI, and if we have a nozzle so much as just barely clog, it'll go up 10-15 PSI. a 5 number pill change is work about 10 PSI and a 1 number nozzle change is about 3 PSI.
Old Dec 25, 2013 | 12:18 PM
  #52
Bigboi407's Avatar
Bigboi407
heres a new one....
Sitting at the store filling my tires up, and i back out of the parking space, into a cloud of Blue smoke, my truck did exactly like my dads ford festive does after sitting too long, idle for a while then hit the gas and blue smoke for just 2 seconds then it dissapears
No smoke while driving, and none after this blue cloud, engine is running PERFECTLY Fine this morning, so ima leave it idling for a bit then tap the gas see if i can make it happen again
Old Dec 25, 2013 | 02:43 PM
  #53
98DAKAZ's Avatar
98DAKAZ
A bad Valve Stem Seal I wonder your head was reconditioned correct?
But if #4 is getting a lot of oil inside it the sparkplug should show it correct you never noticed this before?
Old Dec 25, 2013 | 06:08 PM
  #54
Bigboi407's Avatar
Bigboi407
No oil what so ever on the plugs yet, probably so now after that ball of smoke, And i just put brand new valve seals on my head
im also noticing when the misfire occurs, that this tick/clatter im hearing gets rather loud, and when its firing correctly, i Clearly hear lifter noise
DAKAZ, i have a ground running to the block on the P/S, i didnt see this ground positioned there on the 2.5 in the junk yard, its very close to the firewall only on the P/S, doubt this has anything to do with it, but im adjusting Every little thing possible just to not have to Re-think if somethings wrong or not at this point
Old Dec 25, 2013 | 09:01 PM
  #55
98DAKAZ's Avatar
98DAKAZ
It may take a week before I can help you much this flu or bad cold is knocking me down to the ground been so bad I was hallucinating on and off the last few days. This thing is sucking the life out of me some days I'm so sick I cant move from bed to drink or eat. Yesterday I was thinking it was emergency room time because I was hallucinating constantly.
But I avoid Hospitals or vodo Doctors at all costs I don't trust them. ha ha
I cant wait for vodo Obama care to take over health care like a third world nation we will become.
Good luck
Old Dec 25, 2013 | 10:25 PM
  #56
Bigboi407's Avatar
Bigboi407
Good luck
Ouuuchh... get better sooner!!! i myself try to avoid hospitals at all costs as well.... but i got shot point blank in the stomach, now im waiting to get another surgery, so ill be going back to the hospital once that gets situated, but i feel your pain, i Rarely get sick and when i do, its Serious.....
no rush on snappin a pic of the P/S grounds
Old Dec 27, 2013 | 11:54 AM
  #57
Bigboi407's Avatar
Bigboi407
just tried another distributor cap, Same misfire problem...
wouldnt single coil unit which throws spark to the distributor also throw misfires to other cylinders seeing at it sparks the distributor and not specifically to a cylinder, or do i have that all backwards?
Old Dec 28, 2013 | 02:12 AM
  #58
magnethead's Avatar
magnethead
it "should", but I've seen stranger.
Old Dec 31, 2013 | 05:42 PM
  #59
Bigboi407's Avatar
Bigboi407
Tomorrow im trying...
another coil
Another TB/sensors
Another crank sensor
Annd do another Compression test on #4, my brother insists i do a leak down test before pulling the head, im not in the position to spend $40 on the tool, and wait a few days to take it back, engines eating up some gas when its firing on 3 cylinders
Ill also post the videos up i took this morning
Old Jan 2, 2014 | 04:56 PM
  #60
Bigboi407's Avatar
Bigboi407
i tried everything out, besides the crank sensor
I dropped the head off at the machine shop, and he inspected it for cracks immediately and gave me a thumbs up, informed me the 2.5 is VEERYY bad about cracks
$125 valve job & decked
