bouncing
Old Dec 18, 2013 | 06:28 PM
pizzadoe53's Avatar
pizzadoe53
Default bouncing
new to this truck when I drive the truck is very bouncy, could it be tires 2000 4x4 x cab dakota
Old Dec 18, 2013 | 06:43 PM
Daves69's Avatar
Daves69
Shocks and tires
Old Dec 18, 2013 | 06:56 PM
00DakDan's Avatar
00DakDan
Section Moderator
Bouncy would tell me the shocks are probably shot.
What are you comparing the ride to?
I moved the thread into 2nd gen forum.
Old Dec 19, 2013 | 09:17 AM
sxrsil3nt's Avatar
sxrsil3nt
Jump on your rear bumper and rock the back. If you bounce more than once its a good sign your shocks are shot.
Old Dec 19, 2013 | 03:27 PM
TheNewbie's Avatar
TheNewbie
What pressure are you running in your tires? If you are feeling every little bump in the road and it's more of a jolting feeling then it could be a matter of over inflated tires. Letting the air pressure down a bit will help with ride quality but at the cost of MPG. It's a trade off. Some types of tires give a harsher ride than others too.
Like sxrsil3nt said, if it's bouncing up and down several times instead of once before it levels out you're probably looking at a case of bad shocks.
