04 dakota coolant
Old Jan 10, 2014 | 09:04 PM
mcbride0214's Avatar
mcbride0214
Exclamation 04 dakota coolant
I have an 04 dakota, it is the newest car that I have ever had so I don't know much on working on it. I am having a problem with the thermostat I think, but I really need to know how much coolant the whole system takes and what kind to use. If anyone could help it would be much appreciated.
Old Jan 10, 2014 | 11:53 PM
djibara's Avatar
djibara
size o fengine would be nice but my 05 4.7 dakota holds about 1.5 to alomst 2 gallons make sure and burp the system to get all the air out
Old Jan 11, 2014 | 05:50 PM
mcbride0214
It's a 3.7 v6. And I don't know if it matters but it's an ext. cab 4x4
Old Jan 13, 2014 | 10:12 AM
Robbadodge's Avatar
Robbadodge
The 4.7 takes G05 Zerex
Do not use Dex-Cool
No point in using something compatible with either, just use the manufacturers recommendation.
Old Jan 13, 2014 | 10:39 AM
sxrsil3nt's Avatar
sxrsil3nt
Here is a fluid capacities thread:
https://dodgeforum.com/forum/2nd-gen...apacities.html
But unfortunately it doesn't list the 3.7, only the 4.7 which I would imagine would be similiar since I believe the 3.7 is the 4.7 with 2 less cylinders.
Comparing the 3.9 with the 5.2 (same engine with 2 less cylinders) the numbers are almost the same.
Old Jan 13, 2014 | 11:18 AM
Dakmm's Avatar
Dakmm
Do no use Dex-Cool
Is the G05 Zerex the pink stuff that would've been factory fill on a 4.7? Mine has pink in it, looks super clean at 105K, but not sure if it's ever been changed or not. It's a little low so I need to top off....I assume G05 Zerex would be the stuff to use?
Old Jan 13, 2014 | 11:30 AM
sxrsil3nt's Avatar
sxrsil3nt
ZereX is more of a pale orange colour. Not nearly as dark as dex cool, but not pink either.
I'm not sure of any pink coolants other than Toyota. As far as I know Zerex G05 and green coolant are the 2 main ones for our trucks.
Edit: apparently the Mopar coolant is pink.
Old Jan 13, 2014 | 01:00 PM
Dodgevity's Avatar
Dodgevity
Just FYI, if you have a 4.7L, the thermostat is underneath and is kind of a PITA. When you add the coolant, run the engine till hot with the heat control turned to full hot. Leave the radiator cap off while running, until bubbles stop surfacing (burping). If you don't burp the system, air pockets can cause your engine to overheat in places that won't register on the temp gauge.
Old Jan 13, 2014 | 05:41 PM
Dakmm's Avatar
Dakmm
So the Zerex is fully compatible with the Mopar coolant, regardless of color? Mine isn't a deep pink like Dex-cool, it's a very light pink but could be a light orange also...it's very clean, you would think it's clear until you pull some out with a hydrometer.
Old Jan 14, 2014 | 09:56 AM
Robbadodge's Avatar
Robbadodge
I would think so. It has the same base properties.
