Transmission fluid help!
Old Jan 12, 2014 | 02:00 AM
kickerman's Avatar
kickerman
Default Transmission fluid help!
I have a 2001 dodge dakota 4.7 Lt 5 sp manual how many quarts of fluid do I need what kind do I use also dose auto zone sell the gasket all have to replace?
Old Jan 12, 2014 | 09:33 AM
5-1/2 qts, 75W-90 gear oil. Should be just plugs to drain it and fill it. No gasket.
Old Jan 12, 2014 | 10:31 AM
00DakDan's Avatar
00DakDan
Section Moderator
Not in a Dakota.
It takes 4.8 pints, almost 2 1/2 quarts of Mopar Manual Transmission Fluid p/n 4761526 (updated number is 4874464). That is the ONLY fluid that is recommended for the NV3500. GM also has the same fluid for their version, p/n 12377916
Pennzoil and Amsoil make "syncromesh" fluid which meet the requirements (MS-9224).
It is not 75w-90 gear oil.
Old Jan 12, 2014 | 11:24 AM
01SilverCC's Avatar
01SilverCC
Synchromesh is very good manual trans lube. It's better than OEM Mopar MTL and costs about half. I have used both Synchromesh and Mopar MTL and my transmission always shifts better, shifts smoother and runs quieter on Synchromesh.
Jimmy
