newly purchhased 04 dakota with airbag light on
Old Jan 19, 2014 | 08:44 AM
larryandchristi's Avatar
larryandchristi
Default newly purchhased 04 dakota with airbag light on
Just purchased 04 Dakota. When first start airbag light comes on after approx. 3 seconds. Cant remember exact wording but scanner says passenger side airbag ground to short...any ideas where and what to look for?thanks LT
Old Jan 19, 2014 | 10:08 AM
modlite52's Avatar
modlite52
do the controls on steering wheel (cruise control) work? if not probably the clockspring is bad. not too bad to change
Old Jan 19, 2014 | 01:52 PM
00DakDan's Avatar
00DakDan
Section Moderator
What body style? Do you have the airbag "off" switch?
Look under the dash for the yellow harnesses. They are the airbags. Be careful when doing anything with the system.
I'll move this to the other forum. It should get more hits.
Old Jan 19, 2014 | 02:21 PM
magnethead's Avatar
magnethead
If it is passenger side, it won't be clock spring. But if you have the airbag off switch, I would start there. You can peel the dash back if you open the ashtray andnpull at the upper fascia. Its not screwed in around the radio or HVAC controls, just pull. It is screwed in around the gauges. You should be able to look behind and make sure its plugged in.
