IOD Fuse Challenge
Old Feb 4, 2014 | 12:38 AM
PaquitaRam's Avatar
PaquitaRam
Default IOD Fuse Challenge
Working on a 2000 Dakota. One night, all lamps in the cab suddenly turned on after I close the door. The only way I managed to turned off was by pulling the IOD fuse.
Does any one know where the internal lamps switch is on the door's frame?
Thanks.
Old Feb 4, 2014 | 08:37 AM
00DakDan's Avatar
00DakDan
Section Moderator
Welcome to the forum.
The switches are NOT on the frame. They are part of the door latch assembly.
From the FSM:
The door ajar switches are integral to the door latches on each door. The switches close a path to ground for the Central Timer Module (CTM) when a door is opened, and open the ground path when a door is closed.
The door ajar switches cannot be repaired and, if faulty or damaged, the door latch unit must be replaced.
Old Feb 4, 2014 | 05:46 PM
Dakota Greg's Avatar
Dakota Greg
The switch is in the door jam on my truck, its plain as day obvious its a plastic 1/4 inch wide like piston with a 1 inch wide flat rubber base, my stuck one time silicone lube and was fine. It was a 99 though idk if it changed in 2000
Old Feb 6, 2014 | 12:00 AM
PaquitaRam's Avatar
PaquitaRam
Thank you guys for the suggestions. From them, it seems that the problem would be the door latch assembly. I will check it closely.
Thank you again.
